Is there any option to export a 3D PDF to a format that can be imported into SOLIDWORKS? I've an assembly I need to work on but input data is available only in 3D PDF format. I know I can do the measurement in 3d PDF but that is very time consuming.
Any pointers or guidance will be helpful. Thank you in advance.
Importing 3D PDF into SOLIDWORKS
- x 441
- x 235
Re: Importing 3D PDF into SOLIDWORKS
Are you able to convert the PDF to a step or stl file from the pdf viewer?
I think that's what I did one time. I cannot remember the program I used though.
Free online 3D pdf to STL converter
https://products.aspose.app/3d/conversion/pdf-to-stl#
I could not find an option to do that.berg_lauritz wrote: ↑Sat Jun 04, 2022 1:45 pm Are you able to convert the PDF to a step or stl file from the pdf viewer?
Tried it but unfortunately it didn't worked and gave error that "File is not supported"Tera wrote: ↑Sat Jun 04, 2022 7:13 pm Free online 3D pdf to STL converter
Thanks anyway for your help
Provided the 3D PDF has been written with precise PRC data and not just facets Adobe Acrobat / Tetra4D can export a STEP from the PDF. We do this occasionally to get 3D PDF into Solidworks.
