Find Concentric Circular Features on Different Components
Jordan Brown
x 6
Post by Jordan Brown »
Hello,
I am trying to come up with a way to find which features on different components are concentric in an assembly. For example: tapped hole in one part and cut-extrude in another. Any ideas on the best way to go about this?
My first thought was to select (via API) all of the temporary axes and then check if they are co-axial, but I can't find a way to select them all without selecting the feature first (which would be extremely slow). Unless someone knows how to do this then I need to use some other process.
Any ideas?
HerrTick
x 32
x 310
Re: Find Concentric Circular Features on Different Components
Post by HerrTick »
Traverse faces of each component
For each face
-->is it cylindrical
-->get the axis
-->get axis vector (transform matrix)
Either compare each axis to a reference vector/axis, or collet them all and see what lines up.
Jordan Brown
x 6
Well, that sounds like an idea. I'll give it a try.
Austin Schukar
x 289
x 56
Post by Austin Schukar »
If you're getting a ton of cylindrical faces, you can check whether it's a hole or boss with this macro (CodeStack).
Austin
x 384
x 417
Post by gupta9665 »
Not API way but have you looked into Hole Alignment tool (Tools > Evaluate > Hole Alignment)
