Part Name Mismatch
Part Name Mismatch
My part name in the feature manager does not match In the actual file name.
I think I made this assembly using replace reference and the filename in the feature manager is still referencing the original file.
It is checked into PDM. I thought that might be the issue and checked it in to check. still a problem.
Has anyone seen a similar issue?
Re: Part Name Mismatch
Yeah, this is a feature. Tools > Options > General > External References. If you have Update Component Names When Documents Are Replaced turned OFF, it will allow you to rename the component in Component Properties.
So if you want it to go back to the file name, you can turn that switch on, or just set the Component Name to whatever you want it to be.Blog: http://dezignstuff.com
Can this not be turned on after the fact?
Does that mean that it would be a manual rename in an assembly that was already created?
I did turn that switch on but when I click on the part name to rename it, when it highlights in blue to rename, it shows the correct file name. I select else where and (to un highlight) and it show the incorrect number again?
- x 1652
- x 2058
That's one of those options that have always puzzled me (I know, I know, a lot of things puzzle me). Why is that even an option? When would you not want that name to change in the tree?
It's just like this website. Every body wants something special, and most of the requests contradict another request. The first few years they were making the software, a lot of the settings were copied from Pro/E. But then the Acad people complained. They had to put in options so people could do stuff. Sometimes the options weren't perfect. Some people wanted names in the tree other than the file name because they had to use random filenames. There's always some explanation.Glenn Schroeder wrote: ↑Mon Mar 29, 2021 1:28 pm That's one of those options that have always puzzled me (I know, I know, a lot of things puzzle me). Why is that even an option? When would you not want that name to change in the tree?
- x 1138
- x 1942
That option to display it in the tree didn't exist in the early versions.
You could also do that with the description. But description is for the BOM. People were still living in the world where 2d drawings weren't going to exist.
- x 1138
- x 1942
Is that the world where my flying car exists......still waiting since the 1980s when it was promised to me as a kid.
- x 1652
- x 2058
. . . and the same one where the US is converting to metric. Some (maybe most?) state DoT's tried that in the last century. It was a disaster. I was still on the construction crew here, and I can't tell you how much time we lost when a project would come to screeching halt because stuff didn't fit because of that attempted transition.jcapriotti wrote: ↑Sat Apr 03, 2021 9:09 amIs that the world where my flying car exists......still waiting since the 1980s when it promised to me as a kid.
As far as I know they have all gone back to Imperial.
- x 1138
- x 1942
Glenn Schroeder wrote: ↑Sat Apr 03, 2021 12:23 pm . . . and the same one where the US is converting to metric. Some (maybe most?) state DoT's tried that in the last century. It was a disaster. I was still on the construction crew here, and I can't tell you how much time we lost when a project would come to screeching halt because stuff didn't fit because of that attempted transition.
Our US division is about to convert since the rest of our international divisions are all on metric. Also converting to 1st angle projection. Should be fun.
