create design table in part or assembly
Kjara
Unread post by Kjara »
How do I create a design table in a part or assembly document via SolidWorks API?
I tried to find anything in the API docs, but IDesignTable interface lists only IModelDoc2.GetDesignTable as an accessor.
Typing "design table" in the index also gives no useful results: The only useful I find is the topic "insert", which links me to either IModelDoc2.InsertFamilyTableNew which has to do with drawings and IModelDoc2.InsertFamilyTableOpen which requires an excel file.
I just want to create a new design table, analog to this option in the GUI
but without any user interference and without the user noticing anything.
Answers: 24
x 243
x 401
Re: create design table in part or assembly
Just a quick macro to test this adds a design blank table to a part and then closes it, because it pop up an Excel window.
Option Explicit
    Dim swModel As ModelDoc2
    Set swModel = swApp.ActiveDoc
    swModel.InsertFamilyTableNew
    swModel.CloseFamilyTable
I imagine you'll have to edit the design table feature after the fact with IDesignTable::EditFeature to modify the settings that pop up when a user adds a table with the UI.
