How Do I Twist a Bus Bar in Sheetmetal?
DanBovinich
x 4
x 15
Unread post by DanBovinich »
I'm not that good in Sheetmetal, can only do the basics. I am trying to make a copper bus bar that is twisted 3° on one end.
I tried many things in sheetmetal but couldn't figure it out. I know there are at least a couple of way to make it using normal features like loft and sweep.
If you open the SW part attached to this e-mail you will see what I'm trying to do.
I want the part to be made as a sheet metal part AND be able to flatten it.
Its probably a 5 minute job for you expert sheetmetal guys.
Please upload a sample of it... :)
Thank you,
twisted busbar.SLDPRT
(81.87 KiB) Downloaded 49 times
by Dennis Bacon » Fri Nov 18, 2022 5:09 pm
I'm going to try this again.. Think I'm getting the hang of adding files.. I did this with Lofted-Bend.. Note the two 3D sketches. Your file is a future version for me but I was able to get the info I needed from a dumb solid.
Thank you,
Dan B.
x 1138
x 1942
Re: How Do I Twist a Bus Bar in Sheetmetal?
Sheet metal won't form in this way.....it's mostly for straight bends and some limited cases of bends around a curve.
You could extrude your bar full length then use the "Flex" feature to twist it starting in the middle. Or you could just configure the 3° angle dimension in Sketch3 to 0° in your flat configuration.
Dennis Bacon
x 18
x 30
Unread post by Dennis Bacon »
twisted busbar_db.SLDPRT
(96.25 KiB) Downloaded 70 times
x 1138
x 1942
Dennis Bacon wrote: Fri Nov 18, 2022 5:09 pm I'm going to try this again.. Think I'm getting the hang of adding files.. I did this with Lofted-Bend.. Note the two 3D sketches. Your file is a future version for me but I was able to get the info I needed from a dumb solid.
Nice trick with the lofted bend.
DanBovinich
x 4
x 15
That worked great. I added (2) new 3D sketches with a spline and made the spline tangent to the straight part of bar. Did the lofted bend. Worked like a charm! :D :)
Thank you so much...
Dan B.
Thank you,
Dan B.
