Is there a way to show a sheet metal part's K factor on the .SLDDRW?
Posted: Sat Mar 18, 2023 9:44 am
by Mike Gera
If I have an .SLDDRW of a sheet metal part, is there a way to link text on that .SLDDRW to the part's K-factor?
Re: Is there a way to show a sheet metal part's K factor on the .SLDDRW?
Posted: Sat Mar 18, 2023 12:17 pm
by gupta9665
You can link a note to Bend Allowance cut list property.
Posted: Sat Mar 18, 2023 12:32 pm
by Mike Gera
gupta9665 wrote: Sat Mar 18, 2023 12:17 pm You can link a note to Bend Allowance cut list property.
Thanks, Deepak.
Now to ask an ignorant question, but how do I do that?
Posted: Sun Mar 19, 2023 1:16 am
by gupta9665
Add a note in the drawing attached to the view and link to the custom property "Bend Allowance" as shown in attached video.
Link Note to Bend Allowance.mp4
(4.24 MiB) Downloaded 318 times
Posted: Mon Mar 20, 2023 10:48 am
by TTevolve
Make sure to update, or pick update automatically on the cut list of the part or the cultist options won't appear when you go to add them to the note.
Posted: Mon Mar 20, 2023 11:19 am
by Mike Gera
gupta9665 wrote: Sun Mar 19, 2023 1:16 am Add a note in the drawing attached to the view and link to the custom property "Bend Allowance" as shown in attached video.
Thanks for the video, it was extremely helpful.
One thing that I should have mentioned in my original post, though: I want the K-Factor to appear in my title block (i.e. it will be just text, not a leader that is ultimately associated with an .SLDPRT).
Posted: Mon Mar 20, 2023 12:31 pm
by gupta9665
Use the same method and select "drawing view specified in Sheet properties" option.
Posted: Tue Mar 21, 2023 4:43 pm
by Mike Gera
Deepak,
Thanks for your help. Below is what I see:
Posted: Tue Mar 21, 2023 6:28 pm
by Dennis Bacon
I suppose that you could add that in your "Custom Properties".. Something like this. I added the words "k-factor=" in and got the syntax from "Cut List Properties" cut and paste.
The value is the k-factor value from the "Sheet-Metal" dialog ,which of course your can set that to what is appropriate.
In the drawing you can link a note or text in the bom or title block to that.
Posted: Wed Mar 22, 2023 8:59 am
Dennis Bacon wrote: Tue Mar 21, 2023 6:28 pm I suppose that you could add that in your "Custom Properties".. Something like this. I added the words "k-factor=" in and got the syntax from "Cut List Properties" cut and paste. image.png The value is the k-factor value from the "Sheet-Metal" dialog ,which of course your can set that to what is appropriate.image.png In the drawing you can link a note or text in the bom or title block to that.image.pngimage.pngimage.png
This is what I would go with, careful though, annotations can sometimes be tricky to get to update. Generally not in parts though.
Posted: Wed Mar 22, 2023 1:18 pm
by Mike Gera
Lots of good, helpful ideas here, but it sounds like there is no direct way to line a note to part's bend allowance data.
Posted: Thu Mar 23, 2023 4:07 am
by gupta9665
Mike Gera wrote: Tue Mar 21, 2023 4:43 pm Deepak,
Sorry forgot that cut list won't appear in the list unless you attach to the model. SO like @Dennis Bacon said, you will have to use the custom property route.
