Why... ?
Merovingien
Why... ?
Unread post by Merovingien »
EDIT August 2021 :
i sadly noticed what others people noticed on others internet forum about majority (not all) of american users that think they are the center of the world, it's so obvious when we read some posts.
Talking in a "neutral worldwide forum" without precising country, because america is center obviously center of the world, give a really bad feeling to people from others countries.
I'm sorry to say that but CADforum is not "Worldwide / Neutral"
It's more a "America (self-centered) Forum"
because :
BugidWorks,
StupidWorks,
WorkaroundWorks,
SlowidWorks,
StillBetaWorks
SolidSometimeWorks
SolidDoesntWorks
SolidWorksAround
etc...
Marguerite-Lewis Choquéss.png (54.56 KiB) Viewed 2337 times
Marguerite-Lewis Juge.png (63.22 KiB) Viewed 2337 times
Merovingien
Re: Why... ?
in DRW, for a dimension, when changing default arrow size, it activates the "break"...
x 1638
x 1470
Re: Why... ?
Merovingien
Re: Why... ?
doesn't work for me, i'm don't have account to "that place"
and i can't see-preview of what is it ? can you do a capture ?
x 1638
x 1470
Re: Why... ?
Merovingien
Re: Why... ?
Why the "Reference" under open-recent doesn't work anymore ??? because Bugidworks
in a recent past, it worked...
in recent menu, expand one file, selct "Reference", do the change we want and clic "ok"
and Bugidwork doesn't return the "expand menu", but return to the initial "recent menu"
and all changes under "Reference" are lost.
work arround :
use the "open file / Reference" but it's more clic than the "Recent" menu
use the "SW Explorer" command under windows, but too much slower for me, i don't have time for this...
x 1638
x 1470
Re: Why... ?
I just want to add those tags.
Someone already complained :p
Merovingien
Re: Why... ?
the config order...
x 2546
x 1400
Re: Why... ?
Merovingien wrote: Wed Apr 21, 2021 11:59 am the config order...
LOL ! add PDM into the mix along with edrawings and all the other places one might select which config.
"it's a jungle out there kiddies have a very fruitful day"
x 1638
x 1470
Re: Why... ?
Yeap, engineering software that don't know how to count.
MJuric
x 874
Re: Why... ?
Unread post by MJuric »
Why is SW so ignorant about directions of extrusions. Why is the default not always away from the material. I'd say the majority of the time SW purposefully extrudes sheet metal right into the other parts.
x 1638
x 1470
Re: Why... ?
Same reason SW cut into thin air whenever possible.
Since it keep doing the wrong thing 90% of the time, they should just program it backward.
Merovingien
Re: Why... ?
maybe SW uses the direction of plane, that's why it's important in DOT settings to have two different colors,
(i use green and red)
even a sketch line, or a geometric-axe has a direction, even if we can't see it...
Rob
x 787
x 208
Re: Why... ?
Unread post by Rob »
Frederick_Law wrote: Mon Apr 26, 2021 12:36 pm Same reason SW cut into thin air whenever possible.
There is no business motivation to making the software more efficient as they would sell less licenses.
Heaven forbid they actually release a bug free version.
MJuric
x 874
Re: Why... ?
Merovingien wrote: Tue Apr 27, 2021 3:33 am maybe SW uses the direction of plane, that's why it's important in DOT settings to have two different colors,
Which is why I don't understand why it so often is wrong particularly when working with solids. All surfaces on Solids are normal out so when you place a sketch on a surface of a solid you KNOW where the material is. Cuts should default opposite the normal and extrusions should go in the same direction as the normal whether its a piece fo sheet metal or plain extrusion.
x 2225
x 1876
Re: Why... ?
Rob wrote: Tue Apr 27, 2021 4:12 am There is no business motivation to making the software more efficient as they would sell less licenses.
But they fail to see that all the bells and whistles don't matter if the core software continues to degrade. "Why isn't anyone renewing their license. We've added all these fancy new features."
(The fact that none of those fancy new features work for the first 3 years doesn't seem to register on their radar.)
Rob
x 787
x 208
Re: Why... ?
Added a new feature - works in 2 configs. No error but no effect in 3 others ?
[edit] my bad - I had it slightly in the wrong place and a mirror consumed it
Merovingien
Re: Why... ?
why... not the correct name of a button...
MJuric
x 874
Re: Why... ?
Merovingien wrote: Tue May 11, 2021 12:06 pm why... not the correct name of a button...
Yeah, no doubt. I can't even figure out what that says. Looks like it was written in a foreign language or something. For what it's worth mine seems fine. I'm on 2018 though.
Merovingien
Re: Why... ?
MJuric wrote: Tue May 11, 2021 12:28 pm Yeah, no doubt. I can't even figure out what that says. Looks like it was written in a foreign language or something. For what it's worth mine seems fine. I'm on 2018 though.
it says in french : Welded Bodies !
Fantastic, bravo (clap, clap)
