Angled dimension from vertice
Posted: Wed Sep 06, 2023 10:53 am
Hey,
I know I can do angled dimensions from a vertice but I'm unable to achieve it. Could somone please enlighten me..? The toggle switch just doesn't show up upon selection.
From memory, I'm supposed to select the line and the vertice but I can't seem to get it to work.
Re: Angled dimension from vertice
Posted: Wed Sep 06, 2023 11:14 am
by Dwight
I believe it's either 2 edges or 3 points.
Posted: Wed Sep 06, 2023 11:19 am
Dwight wrote: Wed Sep 06, 2023 11:14 am I believe it's either 2 edges or 3 points.
There was a new thing added which allowed to select a point and then a round blue thing would would appear split in quarters next to the mouse. That's the thing I'm refering to, I just can't find it :lol:
Posted: Wed Sep 06, 2023 11:20 am
by JSculley
Yes, with the dimension tool active, select a line/edge and a collinear point/vertex. The popup should appear.
Officially known as Creating Angular Dimensions Using an Imaginary Line
Posted: Wed Sep 06, 2023 11:33 am
JSculley wrote: Wed Sep 06, 2023 11:20 am Yes, with the dimension tool active, select a line/edge and a collinear point/vertex. The popup should appear.
Hrmm.. Doesn't seem to work in 2023 SP3..?
Posted: Wed Sep 06, 2023 11:37 am
by Ronan
Just tried it on 2023 sp3. Works ok for me. Never knew this before. Nice feature.
Posted: Wed Sep 06, 2023 12:03 pm
by DanPihlaja
As far as I know, it only works if the point AND the line are from the same entity. (i.e., the point is the end point of the line you already selected)
Posted: Wed Sep 06, 2023 12:26 pm
by JSculley
AlexLachance wrote: Wed Sep 06, 2023 11:33 am Hrmm.. Doesn't seem to work in 2023 SP3..?
Are you in a detail view in a drawing? There is a bug report against SW2023 SP3:
BR10000357494 -- Cannot dimension to imaginary lines in detail view
Posted: Wed Sep 06, 2023 12:50 pm
JSculley wrote: Wed Sep 06, 2023 12:26 pm Are you in a detail view in a drawing? There is a bug report against SW2023 SP3:
Ugh, it was appearing misplaced because of a trimmed view... I'm feeling stupid now :lol:
Posted: Fri Sep 08, 2023 1:48 pm
by Krzysztof Szpakowski
DanPihlaja wrote: Wed Sep 06, 2023 12:03 pm As far as I know, it only works if the point AND the line are from the same entity. (i.e., the point is the end point of the line you already selected)
The point must lie on a line or its extension (colinear)
Hmm... A alien doesn't know...
I'm starting to have doubts...
Posted: Fri Sep 08, 2023 2:47 pm
by DanPihlaja
Krzysztof Szpakowski wrote: Fri Sep 08, 2023 1:48 pm The point must lie on a line or its extension (colinear)
I don't understand what you are trying to say here....
