I found another interesting feature today. It is probably programmatically correct as far a SW is concerned.
I am mocking up a PCB for approval from the electrical department. I've got text "wrapped" on the PCB, and have chosen to "use document font." I then went and changed the document font to a size I thought would work. Next I went to the assembly so that I could properly position the text in relation to the terminal block. When I did, the text feature used the "document font" of the assembly, not of the part.
Click me. I am a GIF.
Use document font
Use document font
- x 2191
- x 1892
Re: Use document font
Sounds like a programming mishap. Rather then using the document font of the part, since you are editing from the assembly level, it picks up the current document font rather then the part's document font.SPerman wrote: ↑Thu Oct 12, 2023 4:10 pm I found another interesting feature today. It is probably programmatically correct as far a SW is concerned.
- x 1551
- x 1404
Better to use single character and center on the connector.
Spacing change with font, font size, font style (bold).
And specify font. Use default Windows font.
Windows did add and remove fonts. So nothing is 100%.
My workflow is to use the document font. It frequently takes many different text features to get things aligned properly. Have to change each font individually is too much time.
