BOM sort (sort on insert)
Posted: Tue Dec 12, 2023 9:03 am
by Bryan O
I've created a custom BOM which (on insert) sorts automatically by assembly build order.
I know I can manually sort after the fact but can I get my custom BOM to sort alphabetically by part number(header) on insert?
Re: BOM sort (sort on insert)
Posted: Tue Dec 12, 2023 10:51 am
by gupta9665
After doing the desired sort, save the BOM template. And then next time it should sort on sort, you can right click on the BOM and select sort > apply sort (check reply by @JSculley below)
Posted: Tue Dec 12, 2023 1:57 pm
That does not work for me. (2022 SP5)
Posted: Tue Dec 12, 2023 3:41 pm
by JSculley
I don't think you can. You can save the sort settings to the template, but you must manually apply the saved settings in new documents that use the template. See:
https://help.solidworks.com/2024/Englis ... etting.htm
Posted: Wed Dec 13, 2023 12:22 am
by gupta9665
JSculley wrote: Tue Dec 12, 2023 3:41 pm I don't think you can. You can save the sort settings to the template, but you must manually apply the saved settings in new documents that use the template. See:
Yes that is correct once I rechecked. But it wa working for me earlier and hence I did not add the extra step.
Posted: Wed Dec 13, 2023 11:02 am
by gupta9665
The API person inside me is thinking of a macro using which you insert the BOM and it get sorted as needed.
Posted: Wed Dec 13, 2023 2:26 pm
by Bryan O
Thanks @gupta9665 &@JSculley . Works like I want it to now!
