PDM DataCard: Input formula does not update without interaction
csh
x 4
Unread post by csh »
I have a field (A) in my datacards that I want to be filled automatically using Input formula pulling the value from two other variables/fields (B) and (C).
My problems is that the information in (B) and (C) is automatically filled from Folder data. Meaning there is no user interaction needed.
Some research show that input formulas will only update if the user interact with the datacard.
If I change a character in one of the fields (B) or (C) the whole strings updates. so data is there, and the input fomular is working. It is just not updating without the interaction.
I am looking for a workaround for this problem. Either another way to combine the content of (B) and (C) in (A). Or a way to update, with non or very little interactions from user. I button saying "Update" would be acceptable. but is that even possible.
Any thought on this subject is appreciated!
Input formular update.mp4
(47.8 KiB) Downloaded 104 times
x 278
x 462
Re: PDM DataCard: Input formula does not update without interaction
I can reproduce this, however I don't really have any thoughts on how to remedy this without the use of Dispatch or another custom solution.
Edit: relevant KB article (not possible out of the box) https://support.3ds.com/knowledge-base/ ... 0000106127
ReeceB
x 10
Unread post by ReeceB »
This has been a big headache for me as I could achieve so much QOL niceties if this simply would update automatically instead of requiring user input. Unfortunately I have not found a workaround either apart from running a custom dispatch.
