Hi all,
The attached screenshot is the error message that I got when I tried to use a sketch to make an extruded cut offset from a curved surface. Could it be because the selected surface is curved? Also attached the file to the post.
Any help/insight is appreciated .
Thanks in advance,
Coincident but not merged points...?
- x 26
- x 3
- Leg.SLDPRT
- (106.71 KiB) Downloaded 58 times
You've asked the same basic question in 3 or 4 separate posts. You need to do enough tutorials to understand a closed sketch.
Go to full postRe: Coincident but not merged points...?
