Tapper Thread
- Maha Nadarasa
- x 51
- x 48
Tapper Thread
Nut and Bolt is there to fasten the parts together. What is the purpose of having tapper thread? In my view, it will tend to get loose quickly in the course of time.
- x 178
- x 218
Re: Tapper Thread
Plugs, pipes, etc. Can create gas tight connections without adding any seal, except some lubricant. (Have a look at NPT, NPTF, R, Rp, Rc.)
- x 1565
- x 1409
Re: Tapper Thread
Oil and gas, ground drilling attachment.
Easy disconnect in dirty environment is one benefit.
Re: Tapper Thread
Taper threads act as a both a nut and bolt as well as a sealing element all in one. With a taper you can put a male and female together and just keep tightening until it seals. Without an additional sealing element that is more difficult to do with straight threads because the relationship to OD and ID remain the same regardless of torque applied.Maha Nadarasa wrote: ↑Thu May 20, 2021 7:29 am Nut and Bolt is there to fasten the parts together. What is the purpose of having tapper thread? In my view, it will tend to get loose quickly in the course of time.
They are used largely in fluid fittings and essentially in standard size the designation is NPT which stands for National Pipe Thread.
They don't come loose anymore quickly than a straight thread. Once a straight thread comes loose the nut/Bolt Spins freely. Only difference is that depending on thread length of a straight thread a taper thread comes out with fewer rotations because the threads are clear completely after some number of turns regardless of length.
- x 1142
- x 1947
Re: Tapper Thread
There is also an interference fit which tends to help lock it in place. But as mentioned its for sealing against leaks of gas/oils, etc. We use the NPT type threads for large hydraulic jacks. Also have pipe plugs and bleeders valves. None of these have any sort of locking issues, they are just torqued down.Maha Nadarasa wrote: ↑Thu May 20, 2021 7:29 am Nut and Bolt is there to fasten the parts together. What is the purpose of having tapper thread? In my view, it will tend to get loose quickly in the course of time.
- x 1232
Re: Tapper Thread
Have you never heard of JIC?MJuric wrote: ↑Thu May 20, 2021 10:03 am Taper threads act as a both a nut and bolt as well as a sealing element all in one. With a taper you can put a male and female together and just keep tightening until it seals. Without an additional sealing element that is more difficult to do with straight threads because the relationship to OD and ID remain the same regardless of torque applied.
https://www.daltonhydraulic.com/1-2-fem ... wivel-4638
https://www.mcmaster.com/50695K266/ (They also work for hoses and adapters, not just tubing.)
From finger tight to 5000 psi in less than half a turn!
![lets watch **](./images/smilies/popcorn2.gif)
Re: Tapper Thread
There's a reason god invented o-rings.
- x 1565
- x 1409
Re: Tapper Thread
And God damn we need to design proper o-ring grove.
Need to add torque spec to bolts.
One time use.Need to add torque spec to bolts.
- x 1232
Re: Tapper Thread
Have you never had a numbskull who thought tighter is always better?
![cant..believe... o[](./images/smilies/brickhead.gif)
And yeah, I've seen split #4 JIC hose ends too.....
![hmm maybe not ()](./images/smilies/shuffle.gif)
Re: Tapper Thread
I spent the majority of my adult life working in Nascar. I know all about "tighter is better."
Re: Tapper Thread
Yeah, use them all the time...they don't seal on the threads, and thus "Another sealing element". Sealing straight threads with the threads only is a fools errand at best.mike miller wrote: ↑Thu May 20, 2021 11:22 am Have you never heard of JIC?
From finger tight to 5000 psi in less than half a turn!![]()
- Jaylin Hochstetler
- x 379
- x 355
Re: Tapper Thread
I've seen split #6 JIC hose ends. Guy said, "Yea, I just kept tightening it and it suddenly split!". Well then you obviously made it too tight!mike miller wrote: ↑Thu May 20, 2021 11:43 am Have you never had a numbskull who thought tighter is always better?(note the past tense)
And yeah, I've seen split #4 JIC hose ends too.....![]()
Attached are some JIC and pipe fittings I modeled.
- Fittings and Adapters.7z
- (6.5 MiB) Downloaded 71 times
