Assembly to Part Macro for Solidworks
Library for macros
Ömür Tokman
x 995
x 347
Unread post by Ömür Tokman »
Hello there,
Generates DWG in current view from attached macro assembly file. It works fine for me, I hope someone makes more advanced versions.
Special thanks to @Rob Edwards
basic logic.
Create Part from Assembly
Save to temp folder
Open and save current view as DWG
-SW 2020 sp3-
Replace the temp file path with your own file path.
Option Explicit
Dim swPart As SldWorks.PartDoc
Dim sModelName As String
Dim sModelFullPath As String
Dim TempPartName As String
Dim i As String
    Set swModel = swApp.ActiveDoc
    sModelName = swModel.GetPathName
    sModelFullPath = Left(sModelName, Len(sModelName) - 6) & "dwg"
'    TempPartName = Left(sModelName, Len(sModelName) - 6) & "SLDPRT"
    Dim bs As Boolean
    Dim Errors As Long
    Dim Warnings As Long
    bs = swModel.Extension.SaveAs("C:\Users\Omur\AppData\Local\Temp\tempPart.SLDPRT", swSaveAsVersion_e.swSaveAsCurrentVersion, swSaveAsOptions_e.swSaveAsOptions_Copy, Nothing, Errors, Warnings)
    Set swModel = swApp.OpenDoc6("C:\Users\Omur\AppData\Local\Temp\tempPart.SLDPRT", swDocumentTypes_e.swDocPART, swOpenDocOptions_e.swOpenDocOptions_Silent, "", Errors, Warnings)
    Set swPart = swModel
    Dim alignment(11) As Double
    alignment(0) = 0# ' x origin
    alignment(1) = 0# ' y
    alignment(2) = 0# ' z
    alignment(3) = 0# ' x vector
    alignment(4) = 0#
    alignment(5) = 0#
    alignment(6) = 0# ' y vector
    alignment(7) = 0#
    alignment(8) = 0#
    alignment(9) = 0#
    alignment(10) = 0#
    alignment(11) = 0#
    Dim views(0) As String
'     views(0) = "*geçerli" ' tr
     views(0) = "*current" 'eng
     bs = swPart.ExportToDWG2(sModelFullPath, swModel.GetPathName, swExportToDWG_e.swExportToDWG_ExportAnnotationViews, True, alignment, False, False, 0, views)
     swApp.CloseDoc (swModel.GetPathName)
AssemblyToDwg.swp
(33 KiB) Downloaded 242 times
Answers: 26
x 445
x 469
Re: Assembly to Part Macro for Solidworks
I was thinking of another route using the drawing. Create a drawing with current view at 1:1 scale and export that drawings as DWG/DXF. Refer codes below.
Option Explicit
Dim swDrawing As SldWorks.DrawingDoc
Dim swSheet As SldWorks.Sheet
Dim swDrawPath As String
Dim nErrors As Long
Dim nWarnings As Long
swDrawPath = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, ".")) & "DWG"
'Change Template Name and Paper size here
Set swDrawing = swApp.NewDocument("D:\SolidWorks\SOLIDWORKS 2020\templates\Drawing.drwdot", swDwgPaperAsize, 0#, 0#)
Set swSheet = swDrawing.GetCurrentSheet()
'Change desired view name here, replace Current Model View with your desired name.
swDrawing.CreateDrawViewFromModelView swModel.GetPathName, "Current Model View", 0, 0, 0
swSheet.SetScale 1, 1, True, True
swDrawing.ViewZoomtofit2
swDrawing.Extension.SaveAs swDrawPath, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, nErrors, nWarnings
swApp.CloseDoc swDrawing.GetTitle
Ömür Tokman
x 995
x 347
gupta9665 wrote: Fri Jun 18, 2021 12:15 am I was thinking of another route using the drawing. Create a drawing with current view at 1:1 scale and export that drawings as DWG/DXF. Refer coes below.
I tried but there is something I can't do.
Can you watch the video? where am i doing wrong.
I tried the views in Turkish and English.
video2.mp4
(1.65 MiB) Downloaded 231 times
Answers: 26
x 445
x 469
Did you changed the drawing paper size which is used in the template name?
Another issue could be the view name. Try using *Isometric.
Ömür Tokman
x 995
x 347
gupta9665 wrote: Fri Jun 18, 2021 6:04 am Did you changed the drawing paper size which is used in the template name?
Template 1:1 scale
I tried other view types in Turkish and English, but it didn't work. I feel it is a very simple shortcoming. I will solve it.
Answers: 26
x 445
x 469
I mean the paper size in this line
Ömür Tokman
x 995
x 347
gupta9665 wrote: Fri Jun 18, 2021 7:10 am I mean the paper size in this line
Methods I tried but the page is still blank (not getting model view on the page)
Option Explicit
Dim nErrors As Long
'Set swDrawing = swApp.NewDocument("C:\ProgramData\SOLIDWORKS\SOLIDWORKS 2020\templates\A4 YATAY.drwdot", 12, 0#, 0#)
'Set swDrawing = swApp.NewDocument("C:\ProgramData\SOLIDWORKS\SOLIDWORKS 2020\templates\A4 YATAY.drwdot", swDwgPaperAsize, 0#, 0#)
'Set swDrawing = swApp.NewDocument("C:\ProgramData\SolidWorks\SOLIDWORKS 2020\templates\A4 YATAY.drwdot", swDwgPaperA4size, 0#, 0#)
'Set swDrawing = swApp.NewDocument("C:\ProgramData\SolidWorks\SOLIDWORKS 2020\templates\A4 YATAY.drwdot", 12, 0.297, 0.21)
'Set swDrawing = swApp.NewDocument("C:\ProgramData\SolidWorks\SOLIDWORKS 2020\templates\A4 YATAY.drwdot", 12, 1, 1)
Set swDrawing = swApp.NewDocument("C:\ProgramData\SolidWorks\SOLIDWORKS 2020\templates\Teknik Resim.drwdot", 12, 1, 1)
swDrawing.CreateDrawViewFromModelView swModel.GetPathName, "İzometrik", 0, 0, 0
Answers: 26
x 445
x 469
Try the below line:
Set swDrawing = swApp.NewDocument("C:\ProgramData\SolidWorks\SOLIDWORKS 2020\templates\Teknik Resim.drwdot", 12, 0#, 0#)
swDrawing.CreateDrawViewFromModelView swModel.GetPathName, "*İzometrik", 0, 0, 0
Ömür Tokman
x 995
x 347
gupta9665 wrote: Sat Jun 19, 2021 1:49 am Try the below line:
Yes, it works fine with the attached shape.
Thank you again.
Option Explicit
Dim nErrors As Long
'Replace the temp address below with your own address.
