BOM won't show "Document name"
Posted: Wed Aug 18, 2021 2:01 pm
by MJuric
So I have a part that was downloaded from McMaster Carr. It has one configuration. No matter what I do it will not seem to display the file name in the BOM.
If I go into the configuration properties and set it to "Configuration name" it shows that. If I set it to "User defined" it shows that. If I change it to "Document name" it doesn't change and just shows whatever it was set to last.
I've never seen this so any ideas what the problem is? I'm unaware of any other setting that could cause this.
Thank You,
Edit to Add: This really doesn't tell me what happened and maybe it was just a SW glitch, but I did a "Save as" replacing the part in the assembly and it fixed the issue.
Re: BOM won't show "Document name"
Posted: Wed Aug 18, 2021 2:05 pm
by mike miller
What was the created date of the Top Plane? If a part template was really old, it can cause loss-of-function problems like that.
Opposite of gain-of-function..... For example, if that option was not available in the template version (often 1999 for McMaster
) it may not be available now.
Posted: Wed Aug 18, 2021 2:52 pm
by MJuric
mike miller wrote: ↑Wed Aug 18, 2021 2:05 pm
2/11/2011 2:17:42 PM
Old but I wouldn't think that old.
Posted: Wed Aug 18, 2021 4:23 pm
Check the part properties and see if there is anything in "Configuration Specific." That seems to override the "Custom" tab. I've found SW will fill in the Configuration Specific table when I do a "Save As" on a part.
Posted: Wed Aug 18, 2021 4:27 pm
by MJuric
SPerman wrote: ↑Wed Aug 18, 2021 4:23 pm
That's one of the first things I looked at when changing the config stuff didn't work. I didn't see anything there but I could have certainly missed it.
Posted: Wed Aug 18, 2021 6:36 pm
by David Matula
sometimes just saving and closing helps fix those glitches you where having. Most times I get it to crash and then when I reopen things go better.
Posted: Fri Aug 20, 2021 12:28 pm
by Uncle_Hairball
Post the part, please.
Posted: Fri Aug 20, 2021 1:14 pm
by MJuric
Sorry, parts gone. Probably should have saved it but once I did the "Save as" and the new file worked I nuked the old one.
