Part Reviewer
- Maha Nadarasa
- x 51
- x 48
Part Reviewer
I am not familiar with Part Reviewer. This is a simple part to test the Part Reviewer window but it is blank. How to activate it?
- PartABC-1.SLDPRT
- (1.83 MiB) Downloaded 125 times
- x 1643
- x 1471
Re: Part Reviewer
It let you add comments on each feature.
Its blank because there is no comment in your part.
No, it does not show the part.
- Maha Nadarasa
- x 51
- x 48
Re: Part Reviewer
I usually use Design Builder to add comment about part. This seem you have to add comment somewhere and this window will show it. Because this window will not take any text format.
Re: Part Reviewer
it can be used to analyse step-by-step "how a dude create part, the technics he used, or the dumbiness he used"
- Maha Nadarasa
- x 51
- x 48
Re: Part Reviewer
@Merovingien
Thanks for the link. It help me to clarify the issue.
- Maha Nadarasa
- x 51
- x 48
Re: Part Reviewer
is the PRT "new" ? that mean "design tree empty" ?
Part Reviewer need "a tree"
if PRT not empty, maybe are part of the "Beta-Tester of SW2021"
or maybe it's some install-problem with your computer.
- Maha Nadarasa
- x 51
- x 48
Re: Part Reviewer
Not empty. I attach my file (2020v). You can try. My SWX is a standard version.
- Pattern on a Curved Surface.SLDPRT
- (44.54 MiB) Downloaded 96 times
Re: Part Reviewer
i didn't use 2020, i'm under (SW2021 and 2021 too much problem, as usual)
maybe someone else can try
- Maha Nadarasa
- x 51
- x 48
Re: Part Reviewer
I have 2021v SP2, I use this to open other file if it is 2021v. I nerve use 2021v for my purpose because I have a bitter experience with previous versions with lower SP.
- Maha Nadarasa
- x 51
- x 48
- Ömür Tokman
- x 995
- x 347
Re: Part Reviewer
Hi @Maha NadarasaMaha Nadarasa wrote: ↑Wed May 26, 2021 5:43 am Not empty. I attach my file (2020v). You can try. My SWX is a standard version.
Why is his MB so high?
I know you can draw it simply.
- Maha Nadarasa
- x 51
- x 48
Re: Part Reviewer
@ Ömür Tokman
I replicate the YouTube example. I will entertain it, If you can simplify it.
- x 1643
- x 1471
Re: Part Reviewer
Works in 2021 SP3
- Maha Nadarasa
- x 51
- x 48
Re: Part Reviewer
I had 2021 SP2 but I uninstalled it because of the following reason.
viewtopic.php?f=3&t=609
- x 48
- x 21
Re: Part Reviewer
I'm on 2020 SP5 and I have the same issue. I can't get the top pan.Maha Nadarasa wrote: ↑Wed May 26, 2021 5:21 am In my graphic area top pan is missing. How to fix it?
