So in the attached part file, I'm looking to use "SKETCH Top Piece_Arc Wall" to make an extrusion offset from a curved surface. The error in the attached screenshot pops up when I try to do so.
Any ideas? All help is appreciated
Thanks in advance,
I mean take your original sketch and extrude it like this:Ballfreak10 wrote: ↑Tue Jun 08, 2021 12:41 pm 1.) When you say "extrude box", do you mean to just create an extrusion from a rectangular shape?
Ok, movie time:2.) I've never used the shell or groove tools (I'm still pretty new to SW, to be honest).
hope that helps3.) In what way would this cut be applied?
P.S. Thanks for being so helpful/thorough!
Yeah, I showed you where the zero thickness error is. Don't do it that way. Use the technique I showed you with the shell feature. Fewer features, more correct geometry, better workflow, less messing around with sketches.Ballfreak10 wrote: ↑Tue Jun 08, 2021 10:13 am UPDATE 6/8:
I tried selecting "Translate Surface" and got an error for zero-thickness geometry...
