Convert Entities
Convert Entities
Is it possible to have Convert Entities convert the entire face at once? I always have to run the command at least twice if there is an inner loop. (And if I do the outer loop first, I have to select the inner edges one at a time. I can't just select the face.)
So, the current solution is to run Intersection Curve instead of Convert Entities. It will capture all edges that are laying on the sketch plane.
It is also a much more robust feature than Convert Entities. If new holes are added on that face, they will be automatically captured by a rebuild operation.
Go to full postIt is also a much more robust feature than Convert Entities. If new holes are added on that face, they will be automatically captured by a rebuild operation.
Re: Convert Entities
If it is a planar face, coincident to the sketch plane, use the Intersection Curve.
That gives me the inner loops, but I have to run the command again to get the outer loops. Am I doing it wrong? (click on GIF below)
Try to check the box first.
- image.png (16.92 KiB) Viewed 1661 times
That still only selects the inner loop for me. (2020 SP5)
I want it to select the inner and outer loops at the same time.
- x 177
- x 217
I think currently the UI doesn't provide a way to do it but API does.
Option Explicit
Dim swModel As ModelDoc2
Dim swSelMgr As SelectionMgr
Dim swFace As Face2
Dim EdgeArr() As Edge
Dim swSketch As Sketch
Dim swSketchManager As SketchManager
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then Exit Sub
Set swSketch = swModel.GetActiveSketch2
Set swSketchManager = swModel.SketchManager
If swSelMgr.GetSelectedObjectType3(1, -1) = swSelectType_e.swSelFACES Then
Set swFace = swSelMgr.GetSelectedObject6(1, -1)
If swSketch Is Nothing Then Exit Sub
If swFace Is Nothing Then Exit Sub
EdgeArr = swFace.GetEdges
If IsEmpty(EdgeArr) Then Exit Sub
swModel.Extension.MultiSelect2 EdgeArr, False, Nothing
swSketchManager.SketchUseEdge2 False
- x 755
- x 907
He is trying to grab both the inner loops and the outer loops at the same time
That's great to know. I will use that in the future.Alin wrote: ↑Thu Feb 10, 2022 8:49 am So, the current solution is to run Intersection Curve instead of Convert Entities. It will capture all edges that are laying on the sketch plane.
