Suppressed Missing mates
- x 466
- x 96
I have searched and with reading into some comments on related topics I think I have the answer, but before I hopelessly destroy some assemblies I want to double check. Mates that show as "Suppressed (Missing)" are mates that are to components that are no longer in the model and can be deleted without harming the model or any of it's configurations. Correct?
Thank you
Jim
Thank you
Jim
- x 790
- x 947
Re: Suppressed Missing mates
When you delete a component in an assembly, and you do not have the following checked when you delete it:
If you proceed to edit that mate, you get the following: Generally, these mates are OK to delete.
Then, it will leave the mates inside the tree looking like this:
Notice that there is only 1 component referenced?If you proceed to edit that mate, you get the following: Generally, these mates are OK to delete.
- x 2295
- x 1967
Not necessarly. For instance, we have a cylinder with a flexible configuration that allows it to stretch between it's maximum and minimum range and a configuration for the maximum and one for the minimum. Mates in gray that show up with missing references such as "face" like Dan pointed out are some you can delete, but always be careful while proceeding and double check if you're not sure before saving.Jim Steinmeyer wrote: ↑Thu Aug 29, 2024 3:53 pm I have searched and with reading into some comments on related topics I think I have the answer, but before I hopelessly destroy some assemblies I want to double check. Mates that show as "Suppressed (Missing)" are mates that are to components that are no longer in the model and can be deleted without harming the model or any of it's configurations. Correct?
Thank you
Jim
Edit: if they show up as "suppressed (Missing)" then they are indeed missing a reference and can generally be removed. Often people add a new mate rather then fix the one with the missing reference..
I find it is sometimes handy to fix the broken mate references, rather than delete and start over.
- x 2295
- x 1967
- x 1726
- x 2111
Assuming your Assembly is fully defined, and there is only one configuration, I don't see any reason not to delete suppressed mates. If there are multiple configurations then those mates may not be suppressed in all of them. Without more information about the file that's about the best I can do.Jim Steinmeyer wrote: ↑Thu Aug 29, 2024 3:53 pm I have searched and with reading into some comments on related topics I think I have the answer, but before I hopelessly destroy some assemblies I want to double check. Mates that show as "Suppressed (Missing)" are mates that are to components that are no longer in the model and can be deleted without harming the model or any of it's configurations. Correct?
Thank you
Jim
We delete suppressed mates left by deleting components. We use the setting that has them flagged as errors, to help with clean-up.
- x 1726
- x 2111
Dwight,
You probably already know this, but if you de-select that option then when you delete a component you should get a dialog box asking if you want to delete dependent items, absorbed features, etc. That way you won't need to clean them up.
Again, you probably already know this, but it may help someone else.
Glenn
